[phpBB Debug] PHP Warning: in file [ROOT]/vendor/zendframework/zend-stdlib/src/ArrayObject.php on line 426: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? [phpBB Debug] PHP Warning: in file [ROOT]/vendor/zendframework/zend-code/src/Reflection/MethodReflection.php on line 272: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? [phpBB Debug] PHP Warning: in file [ROOT]/vendor/zendframework/zend-code/src/Reflection/MethodReflection.php on line 275: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? [phpBB Debug] PHP Warning: in file [ROOT]/vendor/zendframework/zend-code/src/Reflection/MethodReflection.php on line 281: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? [phpBB Debug] PHP Warning: in file [ROOT]/vendor/zendframework/zend-code/src/Reflection/MethodReflection.php on line 287: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? [phpBB Debug] PHP Warning: in file [ROOT]/vendor/zendframework/zend-code/src/Reflection/MethodReflection.php on line 296: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? [phpBB Debug] PHP Warning: in file [ROOT]/vendor/zendframework/zend-code/src/Reflection/MethodReflection.php on line 314: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? [phpBB Debug] PHP Warning: in file [ROOT]/vendor/zendframework/zend-code/src/Reflection/MethodReflection.php on line 319: "continue" targeting switch is equivalent to "break". Did you mean to use "continue 2"? Охота и рыбалка это лучшее что может успокоить душу - Туристический форумПропустить
Купил ночной прицел, иду по лесу поглядываю в него вокруг.
Смотрю - обезьяна на дереве сидит.
Не понял. Подхожу ближе - точно обзьяна!
Ещее метров 30 и вижу - рысь. Обхватила лапами дерево так что в ночник казалась как обезьяна.
